代码实现如下
- //对比数据,找到相同字节集的偏移
- int GetInBuffer(const void *pStart, int nLen, const void *pFindBuffer, int nfLen)
- for (int i = 0; i < nLen - nfLen; i++)
- if (memcmp((void *)((ULONG)pStart + i), pFindBuffer, nfLen) == 0)
- return i;
- return -1;
- void ReadQQ(DWORD dwProcessId)
- //由于QQ是使用Unicode字符集的,所以我们使用wchar_t类型
- static wchar_t QQDATA[] = L"Msg2.0.db";
- //MsgEx.db,好像以前有个版本的数据库文件是MsgEx.db,用MsgEx来当关键字检索速度会变慢。
- //但是QQ2010的是用Msg2.0.db的。
- //打开进程
- HANDLE hProcess = OpenProcess(PROCESS_VM_READ | PROCESS_QUERY_INFORMATION, 0, dwProcessId);
- int nMemLen = 28, nMemStart;
- void *pMemAddress = NULL;
- BYTE *bMemBuffer;
- MEMORY_BASIC_INFORMATION mbi;
- memset(&mbi, 0, sizeof(MEMORY_BASIC_INFORMATION));
- wchar_t szQQnumber[15];
- szQQnumber[0] = 0;
- //寻找进程空间
- while (VirtualQueryEx(hProcess, pMemAddress, &mbi, nMemLen) != 0)
- if (mbi.Type == MEM_PRIVATE && mbi.Protect == PAGE_READWRITE)
- //分配足够的内存空间,存放数据
- bMemBuffer = new BYTE[mbi.RegionSize + 1];
- bMemBuffer[mbi.RegionSize] = 0;
- if (ReadProcessMemory(hProcess, pMemAddress, bMemBuffer, mbi.RegionSize, NULL))
- //尝试寻找当前内存空间中是否包含Msg2.0.db
- nMemStart = GetInBuffer(bMemBuffer, mbi.RegionSize, QQDATA, sizeof(QQDATA));
- if (nMemStart != -1)
- //向前推一定位置,因为路径是 ..\[QQ号]\Msg2.0.db
- wchar_t *pQQText = (wchar_t *)&bMemBuffer[nMemStart - 28];
- wchar_t *pQQstart = wcsstr(pQQText, L"\\");
- if (pQQstart)
- pQQstart++;
- wchar_t *pQQEnd = wcsstr(pQQstart, L"\\");
- if (pQQEnd)
- lstrcpynW(szQQnumber, pQQstart, pQQEnd - pQQstart + 1);
- wprintf(L"%s\n", szQQnumber);
- delete[] bMemBuffer;
- //销毁刚刚分配的内存空间
- pMemAddress = (void *)((ULONG)pMemAddress + mbi.RegionSize);
- CloseHandle(hProcess);
- void FindQQ()
- DWORD dwProcessId = 0;
- //进程快照~
- HANDLE Snapshot = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS,0);
- PROCESSENTRY32 pl;
- pl.dwSize=sizeof(PROCESSENTRY32);
- bool bmore=Process32First(Snapshot, &pl);
- while(bmore)
- if(lstrcmpi(pl.szExeFile, _T("QQ.exe")) == 0)
- //读取QQ号
- ReadQQ(pl.th32ProcessID);
- //dwProcessId = pl.th32ProcessID;
- //循环,读取本地所有登录的QQ号。
- //break; 跳出循环
- bmore= Process32Next(Snapshot, &pl);
- CloseHandle(Snapshot);
- // return dwProcessId;
- int _tmain(int argc, _TCHAR* argv[])
- FindQQ();
- scanf("%*c");
