我们需要监控用户的互联网行为,则需要检测HTTP 如何在网络层截取HTTP呢,众所周知,网站是80号端口
代码实现如下: - CInitSock theSock;
- void GetFtp(char *pData, DWORD dwDestIp)
- char szBuf[256];
- static char szUserName[21];
- static char szPassword[21];
- if(strnicmp(pData, "USER ", 5) == 0)
- sscanf(pData + 4, "%*[ ]%s", szUserName);
- else if(strnicmp(pData, "PASS ", 5) == 0)
- sscanf(pData + 4, "%*[ ]%s", szPassword);
- wsprintf(szBuf, " Server Address: %s; User Name: %s; Password: %s; \n\n",
- ::inet_ntoa(*(in_addr*)&dwDestIp), szUserName, szPassword);
- printf(szBuf); // 这里您可以将它保存到文件中
- void DecodeIPPacket(char *pData)
- IPHeader *pIPHdr = (IPHeader*)pData;
- int nHeaderLen = (pIPHdr->iphVerLen & 0xf) * sizeof(ULONG);
- switch(pIPHdr->ipProtocol)
- case IPPROTO_TCP:
- TCPHeader *pTCPHdr = (TCPHeader *)(pData + nHeaderLen);
- switch(::ntohs(pTCPHdr->destinationPort))
- case 21: // ftp协议
- GetFtp((char*)pTCPHdr + sizeof(TCPHeader), pIPHdr->ipDestination);
- case 80: // http协议...
- case 8080:
- case IPPROTO_UDP:
- case IPPROTO_ICMP:
- // 创建原始套节字
- SOCKET sRaw = socket(AF_INET, SOCK_RAW, IPPROTO_IP);
- // 获取本地IP地址
- char szHostName[56];
- SOCKADDR_IN addr_in;
- struct hostent *pHost;
- gethostname(szHostName, 56);
- if((pHost = gethostbyname((char*)szHostName)) == NULL)
- return ;
- // 在调用ioctl之前,套节字必须绑定
- addr_in.sin_family = AF_INET;
- addr_in.sin_port = htons(0);
- memcpy(&addr_in.sin_addr.S_un.S_addr, pHost->h_addr_list[0], pHost->h_length);
- printf(" Binding to interface : %s \n", ::inet_ntoa(addr_in.sin_addr));
- if(bind(sRaw, (PSOCKADDR)&addr_in, sizeof(addr_in)) == SOCKET_ERROR)
- // 设置SIO_RCVALL控制代码,以便接收所有的IP包
- DWORD dwValue = 1;
- if(ioctlsocket(sRaw, SIO_RCVALL, &dwValue) != 0)
- return ;
- // 开始接收封包
- printf(" \n\n begin to monitor ftp password... \n\n");
- char buff[1024];
- int nRet;
- while(TRUE)
- nRet = recv(sRaw, buff, 1024, 0);
- if(nRet > 0)
- DecodeIPPacket(buff);
- closesocket(sRaw);
评分
查看全部评分
