核心代码如下:
- #include "StdAfx.h"
- #include "Function.h"
- CString GetDiskNumber(CString name)
- HKEY hkey;
- char sz[256];
- DWORD dwtype,sl = 256;
- int number=0;
- // 确定选择的磁盘
- for(int i=1;i<8;i++)
- if(RegOpenKeyEx(HKEY_LOCAL_MACHINE,"SYSTEM//CurrentControlSet//Services//Disk//Enum",/
- NULL,KEY_ALL_ACCESS,&hkey)==ERROR_SUCCESS)
- CString id;
- id.Format("%d",i);
- if(RegQueryValueEx(hkey,id,NULL,&dwtype,(LPBYTE)sz,&sl)==ERROR_SUCCESS)
- CString str=(CString)sz;
- if(str.Compare(name)==0)
- number=i;
- CString driver="////.//PHYSICALDRIVE";
- CString num;
- num.Format("%d",number);
- driver+=num;
- return driver;
- int ReadDisk(CString driver,unsigned char *Buf,long addr)
- HANDLE hDevice;
- BOOL bResult;
- DWORD bytesread;
- hDevice=CreateFile(driver,GENERIC_READ|GENERIC_WRITE,
- FILE_SHARE_READ|FILE_SHARE_WRITE,NULL,OPEN_EXISTING,0,NULL);
- if(hDevice==INVALID_HANDLE_VALUE)
- AfxMessageBox("Error!");
- if(addr!=0)
- SetFilePointer(hDevice,512*addr,NULL,NULL);
- bResult=ReadFile(hDevice,Buf,512,&bytesread,NULL);
- if((bResult==FALSE)||(bytesread<512))
- CloseHandle(hDevice);
- return 1;
- int WriteDisk(CString driver,unsigned char *Buf,long addr)
- HANDLE hDevice;
- BOOL bResult;
- DWORD bytesread;
- if(addr!=0)
- bResult=WriteFile(hDevice,Buf,512,&bytesread,NULL);
- return 1;
- void PopupUSBDevice()
- char strSystemDirectory[256];
- GetSystemDirectory( strSystemDirectory, 256 );
- CString strTemp = strSystemDirectory;
- strTemp += "//rundll32.exe shell32.dll,Control_RunDLL hotplug.dll";
- WinExec( strTemp, SW_SHOW );
调用代码如下
- BOOL CMSSDlg::OnInitDialog()
- CDialog::OnInitDialog();
- // Add "About..." menu item to system menu.
- // IDM_ABOUTBOX must be in the system command range.
- ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
- ASSERT(IDM_ABOUTBOX < 0xF000);
- CMenu* pSysMenu = GetSystemMenu(FALSE);
- if (pSysMenu != NULL)
- CString strAboutMenu;
- strAboutMenu.LoadString(IDS_ABOUTBOX);
- if (!strAboutMenu.IsEmpty())
- pSysMenu->AppendMenu(MF_SEPARATOR);
- pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
- // Set the icon for this dialog. The framework does this automatically
- // when the application's main window is not a dialog
- SetIcon(m_hIcon, TRUE); // Set big icon
- SetIcon(m_hIcon, FALSE); // Set small icon
- // TODO: Add extra initialization here
- HKEY hkey;
- char sz[256];
- NULL, KEY_ALL_ACCESS, &hkey)==ERROR_SUCCESS)
- CString id;
- m_select.AddString(sz);
- RegCloseKey(hkey);
- m_select.SetCurSel(0);
- if(m_select.GetCount()==0)
- AfxMessageBox("没有发现移动设备!");
- return TRUE; // return TRUE unless you set the focus to a control
- void CMSSDlg::OnSysCommand(UINT nID, LPARAM lParam)
- if ((nID & 0xFFF0) == IDM_ABOUTBOX)
- CAboutDlg dlgAbout;
- dlgAbout.DoModal();
- CDialog::OnSysCommand(nID, lParam);
- // If you add a minimize button to your dialog, you will need the code below
- // to draw the icon. For MFC applications using the document/view model,
- // this is automatically done for you by the framework.
- void CMSSDlg::OnPaint()
- if (IsIconic())
- CPaintDC dc(this); // device context for painting
- SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
- // Center icon in client rectangle
- int cxIcon = GetSystemMetrics(SM_CXICON);
- int cyIcon = GetSystemMetrics(SM_CYICON);
- CRect rect;
- GetClientRect(&rect);
- int x = (rect.Width() - cxIcon + 1) / 2;
- int y = (rect.Height() - cyIcon + 1) / 2;
- // Draw the icon
- dc.DrawIcon(x, y, m_hIcon);
- CDialog::OnPaint();
- // The system calls this to obtain the cursor to display while the user drags
- // the minimized window.
- HCURSOR CMSSDlg::OnQueryDragIcon()
- return (HCURSOR) m_hIcon;
- void CMSSDlg::OnExit()
- // TODO: Add your control notification handler code here
- CMSSDlg::OnCancel();
- LRESULT CMSSDlg::WindowProc(UINT message, WPARAM wParam, LPARAM lParam)
- if (WM_DEVICECHANGE == message)
- m_select.ResetContent();
- HKEY hkey;
- char sz[256];
- CString id;
- return CDialog::WindowProc(message, wParam, lParam);
- void CMSSDlg::OnAddPassword()
- unsigned char MBRBuf[512];
- CString name;
- CString driver;
- int id; // 选择移动设备的编号
- if(m_select.GetCurSel()==CB_ERR)
- AfxMessageBox("请选择要加密的设备!");
- id=m_select.GetCurSel();
- m_select.GetLBText(id,name);
- // 确定选择的磁盘
- driver=GetDiskNumber(name);
- // 读磁盘的MBR区
- if(ReadDisk(driver,MBRBuf,0)==0)
- /* RC4加密,KEY是密钥,此处Key[]="MobileStorageSecurity",后期可以
- 用户输入的密码作为密钥 */
- RC4_KEY rc4_key;
- build_rc4_key(Key,strlen((char*)Key),&rc4_key);
- rc4_handler(MBRBuf,strlen((char*)MBRBuf),&rc4_key);
- // 将加密后的MBR写入磁盘
- if(WriteDisk(driver,MBRBuf,0)==0)
- AfxMessageBox("加密成功!");
- // 弹出USB存储设备
- PopupUSBDevice();
- void CMSSDlg::OnRemovePassword()
- CString name;
- CString driver;
- // 确定选择的磁盘
- // 读磁盘的MBR区
- 用户输入的密码作为密钥 */
- RC4_KEY rc4_key;
- // 将解密后的MBR写入磁盘
- AfxMessageBox("解密成功!");
- // 弹出USB存储设备
- PopupUSBDevice();
